Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 01-31-2010, 10:06 AM
tomhrhr tomhrhr is offline
Bleed ABS Brakes?
I have an 06 Uplander LS...changed the calipers...redid the rotors...can't figure out how to bleed the ABS brakes....anyone know how?
Old 01-31-2010, 11:38 AM
maxwedge maxwedge is offline
A990 racer
Re: Bleed ABS Brakes?
If the abs unit has air in it you will need a scanner the can perform this function, have you tried just doing a standard bleed?
Old 01-31-2010, 01:06 PM
tried the standard bleed and would not work....
Old 01-31-2010, 03:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Like what is not working?
Are you getting fluid out bleeders?
If one end will not bleed crack bleeder on other end.
And see if that helps.
MT
Old 02-01-2010, 10:24 AM
I just needed to give it a try 4 or five times...must have been a lot of air in there....but now it did work....thanks to all!!!!
