Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-11-2003, 08:22 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Forced air induction
This is kind of silly but it seems that a lot of you know your stuff so I'll through this out there. What would happen if you were to rig your air intake so that you could connect an air hose to it. Then you get a shop air compressor and run it in the passenger seat and force 120psi into the intake? I just thought that would be funny, and I'm kind of curious as to actually what would happen.
Old 04-11-2003, 09:58 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
sounds pretty cool, but how would u power it? That would kill your battery in 2 minutes.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 04-11-2003, 10:31 PM
loesch8102's Avatar
Gasoline man! I'm talkin a 5 hp generator.
Old 04-13-2003, 02:51 AM
well, some companies make electric fans that u stick into the intake. they claim 5-15 hp. try it and see what happens. Won't the generator get hot and burn ur seats. and it will be crazy loud too. dont forget to have the air filtered.
Clear Corners
Iridium Spark Plugs
Old 04-13-2003, 08:27 PM
ZeRo-MaX ZeRo-MaX is offline
What about just a hose that comes from outside(infront) and goes to near the intake? like the hose picks up cold air when you go fast and shoot it at the intake??? would that work?
Z - Until They Noticed Me,I Got The Feds Wondering Who Broke The Law, Seen a Maxima Fly By That Droped Their Jaw
1995 Maxima GLE "Forever Pimpin', Never Slippin' "
Old 04-13-2003, 10:19 PM
the air pressure would drop too much by the time it worked its way to the engine.unless u put it right on the filter and then u'd rip through the filter in a very short while.
Clear Corners
Iridium Spark Plugs
Old 04-14-2003, 02:40 PM
GSR GSR is offline
Send a message via AIM to GSR
no it wont work. psi is a measure of pressure within a certain space or resistance. a small compressor cant flow enough cfm to build substantial pressue in the engine/manifold. 120psi going through a 1/2" hose would not = 120psi filling 1834cc of displacement plus the head, intake manifold, and piping's volume. the best example i can hink of is a staw and a paper towel tube. blow through each one and see how much pressure you can build before you run out of breath. air guns/tools dont need much air flow, they only need pressure. our engines need more airflow and less pressure.
looking for a 95+ 240sx in/near D F Dub area
Old 04-15-2003, 05:15 PM
loesch8102's Avatar
I hear ya. That makes sense.
