Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-30-2010, 01:33 AM
ned032002's Avatar
ned032002 ned032002 is offline
Rear pumpkin seal leaking?
If the title to this thread makes no sense, feel free to change it to the more appropriate title please.
I was under my car today and noticed that the back pumpkin appears to be leaking. Where do I go to get this seal, and what is the exact name of it?
Sorry for the bad pic, kind of a PITA to get a good pic under the car when you can't even see it from the back.
and how much of a B***h is it to do this seal? The gas tank appears to be hindering easy access.
Old 01-30-2010, 09:44 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Rear pumpkin seal leaking?
Is this on the rear diff cover? I have never replaced this gasket on an eclipse but I have on trucks. Im sure the process is basically the same, drain the diff fluid, take out the bolts on the rear cover and replace the gasket. Then put fluid back in.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-30-2010, 11:06 AM
ned032002's Avatar
I'm going to get a better pic of it tonight but it looks like there's 2 supports the come together and hold the differential in place. Those look like there the biggest obsticle in the way. Plus the front end is on ramps so the rear end is low enough that I can't get under the car to get a good look. Looks like its leaking pretty good too.
Old 01-30-2010, 11:41 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
To me, it looks like its the pinion seal thats leaking, and the fluid is slowly flowing back towards the rear of the housing.
IMO that leak is not so bad. Gear lube does not seem to drip or run off. It simply clings to the housing, so sometimes leaks look worse than they actually are. Check the fluid level on occasion. You might find it is not dropping fast at all.
I have several vehicles with similar leaks. I find I can keep up with them simply by topping up the level at every oil change. But those are crappy old trucks. Since this is a nice car, it may be worth fixing it properly, eventually.
