Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 01-29-2010, 04:28 PM
jakigaga jakigaga is offline
Corolla 2008 help: CEL & won't accel over 40 kph
My car has developed a fault nd it has been to d shop twice but dey say nothing is wrong wit it.the problem is dat the check engine system light comes on nd den car wont go pass 40km/h even if d accelerator is floored,d only way to get it back to normal is to stop,switch off d engine for say 30 mins nd it becomes normal again.can some1 pls help tanx in advance.
Old 02-04-2010, 01:30 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Corolla 2008 help
First off, welcome to AF!
Second, please refrain from using "text speak" typing in these forums. It may be convenient for you, but ends up making it harder for everyone else to decipher and it also prevents the search engine from working as it should to help find similar problems in this forum. Thanks!
The best way to start pinpointing the problem is to connect the car to a OBD code scanner. When a problem is detected by the car's engine control computer, or ECM, a code is stored in the memory and the "check engine" light is lit up. Even if the light goes out, the code should still be in the memory.
Don't know where you are at so it is hard to make a guess off-the-cuff. But I would start with the intake (filter, MAF sensor), electrical (plugs, wires), and emissions control (EGR, IAC, and other valves). In the US, most parts stores will read your trouble codes for free, except California.
Hope this helps and welcome again to AF!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
