Old 01-29-2010, 01:52 PM
oneroundko's Avatar
oneroundko oneroundko is offline
Blinkers Stopped Working all of a Sudden
'96 Z-24 2.4L with power windows and locks.
Any ideas? I don't think it's the switch, and I just recently put in a new battery which may or may not have done something to some wiring somewhere. I have checked all fuses (I think) and they seem to all be in order. Happen to anyone before?
Old 01-29-2010, 07:18 PM
bwtvtech bwtvtech is offline
Re: Blinkers Stopped Working all of a Sudden
That problem happened on my 97 standard model, the "turn signal" fuse
although it was not open had slight corrosion buildup on the contacts, i scraped the contact areas with a knife, re-install the fuse and normal working turn signals again.
Old 01-29-2010, 08:18 PM
oneroundko's Avatar
That's the fuse in the interior right, on the side of the dash board only accesible after the door is open?
Old 01-29-2010, 09:09 PM
Yes, drivers side, far left on side of dash, only accessible with drivers door open, i think it was a 10 Amp fuse (red) , look at the fuse location label on the removable fuse panel door. I think it has multiple circuits tied to the fuse i pulled. I checked the owners manual for the correct fuse, i think it was the "3rd" fuse up on the side - again, check the owners manual fuse section for the exact fuse location.
Old 01-29-2010, 09:25 PM
oneroundko's Avatar
Okay. I'll try tomorrow, but I do know I checked all those fuses and they were all good. If in fact the conection prongs are corroded and it works, it would be a minor miracle.
Old 01-29-2010, 09:44 PM
the fuse will check good , it's the intermittent - poor contact that was causing the problem on mine (not allowing sufficient voltage through the fuse - causing electrical resistance ) hope it is the same with yours. Just clean the contacts - or scrape with knife.
Old 01-30-2010, 10:22 AM
It was the 20 amp yellow " HAZ " "STOP HAZ" fuse tied in with Turn Signal circuit. Again, buildup-corrosion on a metal conductor won't be a sufficient electrical conductor for higher current to flow through. When the Hazard or Turn Signals are switched on the relay passes Higher Current through the circuit.
