Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-28-2010, 06:44 PM
67stang/sable 67stang/sable is offline
Allignment Issues
Hi all, I have a 96 explorer I replace front susp. ball joints tie rods & rack. I took it for allignment & my specs are all in the green, but for some reason i have a slight pull to the right. I am not sure what to check next. My specs are Left front camber -0.25 / caster 4.10 / Toe 0.04 Set back 0.25. The right side camber -0.79 / caster 3.92 / toe 0.03 Total front toe 0.07. Please I need some help here Any help would be greatly appreciated. Thank you in advance
Old 01-28-2010, 07:07 PM
RahX RahX is offline
Re: Allignment Issues
Have you swapped tires front to rear or side to side on the front to see if the pull changes/goes away?
Old 01-28-2010, 07:45 PM
Yea I tried that. Plus the tires are 6 months old. The pull stayed the same.
Old 01-28-2010, 10:21 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Does it just pull to the right in city driving or does it also pull on the highway, assuming no appreciable wind? Many city streets have a crown to them to aid in water run-off. This can contribute to a vehicle pulling towards the curb, which is usually on the right. The crown on highways will be MUCH less pronounced.
-Rod
Old 01-28-2010, 10:39 PM
old_master's Avatar
Advisor/Moderator
Three terms in wheel alignment that can affect pull or drift not mentioned are:
Thrust angle is the direction the rear wheels are headed in relation to the centerline of the vehicle. If the rear wheels are headed to the right, the vehicle will drift to the left, and vice versa.
Cross camber and cross caster: They are the difference in the adjustments from left side to right side. As a rule of thumb, the tolerance is .5 degrees. Caster will affect pull approximately twice what camber will. For example: .5 degrees of camber will cause the same amount of pull or drift that .25 degrees of caster will. If cross camber is .5 degrees favoring the left and cross caster is .5 degrees favoring the left, technically the vehicle is within specs BUT, the vehicle will pull like a big dog to the left if you let go of the steering wheel. This is where an experienced alignment technician is a must. He needs to know how to deal with cross camber and cross caster and how to compensate for it, while also paying attention to thrust angle.
Your specs:
Cross caster is .18 degrees and will cause a slight drift to the right.
Cross camber is .54 degrees which will cause a stronger drift to the left that will more than cancel out the cross caster. Bottom line is you have a .36 degree drift to the left. Take into consideration road crown, and the vehicle should track very well.
If the vehicle is pulling to the right, something other than the alignment is causing it. There are other things that can cause a pull or drift such as:
Radial tire pull, (already mentioned).
Memory steer: caused by incorrect replacement procedure of outer tie rod ends, idler arm, pitman arm, upper ball joints, & lower ball joints. When any of these parts are replaced, the wheels must be straight ahead when tightening the fastener.
Thrust angle: The direction the rear wheels are headed, checked during alignment.
Problem with spool valve or centering valve, in the power steering gear box.
Hope this helps.
You have to know how it works,
to figure out why it doesn't.
Old 01-29-2010, 01:08 AM
How about a dragging brake?
Old 01-29-2010, 03:29 PM
old_master's Avatar
Advisor/Moderator
Good point! That'll open up a whole 'nother can of worms Restricted hose, stuck caliper piston, seized hardware, hung up parking brake, etc etc.
Old 01-29-2010, 05:07 PM
I checked the draging brake issue. And swaped tires but no luck. Thats what i thought was causing it. Also it pulls in city & highway. So, I am looking in the wrong area
Old 01-29-2010, 07:09 PM
Would the ride height affect the allignment. I checked ride height and left/driver side is a 1/2 inch lower than the right/pass side. If anything i would think it would pull to the left. It should pull to the lower side if i am correct. Thanks for everyone's help
Old 01-29-2010, 07:33 PM
old_master's Avatar
Advisor/Moderator
Chassis ride height should be checked and corrected if necessary BEFORE doing the alignment. It will require spring replacement to correct it on your Explorer. If the alignment is done before correcting chassis ride height, it will not cause a drift or pull. If ride height is different side to side, it may cause a brake pull to the lower side.
Old 01-29-2010, 10:44 PM
My torsion bars have adjusters. So the ride height can be adjusted. Thanks old_master
Old 01-29-2010, 10:55 PM
old_master's Avatar
Advisor/Moderator
I stand corrected, I thought it had coils in the front. At any rate, if ride height is adjusted AFTER the alignment it will affect toe and probably camber also. Caster will change, but very little.
Old 01-29-2010, 11:15 PM
consultIII consultIII is offline
there is no mention of the rear alignment numbers...they did do a four wheel alignment not two...right?
have had this happen before...cranked the alignment numbers to compensate for the pull and did not correct it. cross rotated tires, front then rear; no change. swapped 4 tires and wheel assemblies from a similar vehicle and then it drove straight. Would have liked to road force the original tires to see what the radial variation was but just recommended tire replacement.
Are the tires an economy or a quality tire?
Old 01-29-2010, 11:21 PM
why does a brake pull occur with ride height difference?
Old 01-30-2010, 12:26 AM
shorod's Avatar
SHO No Mo
The '96 Explorer has a solid rear axle with no adjustments/shims/camber kit capability, therefore no 4 wheel alignment. The best they could do is a thrust angle alignment.
-Rod
