| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
What about a aftermarket O2/HO2 sensors!
Heated O2 sensors (H20) = 3-wire, and 4-wire types.
Unheated O2 sensors (02) = 1-wire, and 2-wire types. It's really worth the cost savings to save your old connectors during replacement. We only replace the upstream sensor's, they are used for the Air/fuel mix, the down stream are only replaced when they are hard at fault. Last edited by danielsatur; 01-29-2010 at 09:49 PM. |
Re: What about a aftermarket O2/HO2 sensors!
Hunh? What's the point?
-Rod |
One advantage is keeping the OEM connectors would probably be a more reliable connection versus the crimped-on universal type.
Second, it is literally plug & play...no farting around with which wire is which. If it is just a 1-wire, then I see little to no advantage here. Finally, I would think that a sensor that has the correct connector has been at least thought about by the mfr and specified for use in that vehicle or vehicle brand. Universals are just that...cranked out at the factory and thrown in a box. Food for thought....
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
i had success w/ both styles...
some aftermarkets do come w/ the OEM connectors if you're good at soldering/heatshrinking, the "universals" worked ok as well... just compare the prices... i won't go to a no-name aftermarket brand though |
Down stream O2 simulators can be found @ www.o2simulator.com , www.bigdaddiesgarage.com ,or Ads by Google @ the bottom of post.
We have seen alot of people blow $200 for O2 sensors, that didn't need replaced. |
