Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 01-28-2010, 09:45 AM
65 Elco 65 Elco is offline
Choke Help 65 Elco
For a 1968 350 on my 65 Elco -
Runs smooth once started - hard to start I think due to choke problems -
Using the old school 3 pumps of Gas and peddal to the floor while starting will usually work but takes too many cranks usually.
Should choke be opening more at the start or closing more at the startup?
Has the spring mechanism which I replaced - what would other adjustments be? Should I advance it so more open or set it so choke is more closed?
Thanks,
Old 01-31-2010, 06:18 PM
rhandwor rhandwor is offline
Re: Choke Help 65 Elco
Look in the top the choke should be closed when pressing the throttle. The vacuum pull off should open it about 1/4 inch. Use a 1/4 drill bit and set this with vacuum on the pull off. I use a vacuum pump some can suck on a vacuum hose to open it. Watch that the accelerator pump gives it a shot of fuel when pressing on the throttle.
Old 01-31-2010, 07:14 PM
maxwedge maxwedge is offline
A990 racer
Good advice from rhandwor, but post the make and type of carb, no?
Old 02-01-2010, 08:10 AM
Great adivice - I will try that
I rebuilt the carb and wondered if I had put the vaccum lead at the right outer port - (one is plugged and one goes to the choke) - obviously I can try switching them but my test time would seem to be only when the car is cold and had not been started for awhile.
Carb is an Edelbrock - standard 4 barrel - # evades me 3250 maybe
Thanks,
Chuck
Old 02-01-2010, 12:10 PM
As you purchased a kit for the carburetor I would use recommended settings. I gave you a common one as you didn't state the type.
Old 12-25-2013, 06:11 PM
1964 Ford Falcon - looking for a radio bezel and a glove compartment cover Bezel for a 1964 Ford Falcon Futura Convertible - thanks,
