Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-27-2010, 05:42 PM
JL KINGw7 JL KINGw7 is offline
sea foam
whats the best way too use sea foam in my crank case... should i add to gas and crank and should i change oil after whats a sea foam blow out
Old 01-27-2010, 05:57 PM
j cAT j cAT is offline
Re: sea foam
why do you think you need sea foam ??? what is the issue with the engine?
changing the oil at the regular intervals 3,ooomi or every 6 months when hot is a normal proper maintenence interval..adding a few ounces prior to oil change works to clean out the crankcase..
sea foam is good if something failed which caused the crankcase to get fouled with contaminates..
injecting sea foam into the engine by way of the vacuum lines is risky business as the engine can be damaged if not done correctly..
adding a few ounces to the fuel when filling the tank works good/ safer..
Old 01-28-2010, 02:08 PM
Re: sea foam
thankz in the morning time first crank of the day it has just started this ticking till it warms up alittle but i added it and it seems too be fine
Old 01-28-2010, 02:25 PM
Re: sea foam
this would be lifter noise....you need to change your oil more often and also when hot...changing oil especially dino oil when cold will cause lifter noise...the carbon is built up into the engine internal componets and this interfers with the lifters ability to hold oil...
I always use marvel mystrey oil to remove carbon from the engine..this product is safe and will not damage any seals..I have used this for decades in all engines big and small...
It only takes 1 ounce /quart of engine oil to clean your engine over a few hundred miles then change the oil to remove all that damaging carbon ...your engine will sound very quiet and should run smoother..
so your engine would need about 5 ounces of this product...more is not better...this is the correct amount to clean those lifters ...when the oil turns black change the oil/filter and don't use cheap fram filters...get wix,purolator PURE ONE, or mobil 1 ...
Old 01-28-2010, 04:01 PM
Re: sea foam
thankz j-cat i'll do thats and see how see runs!!!!
