Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-27-2010, 04:49 PM
jncharve35 jncharve35 is offline
Coil over plugs!!!!
What are the best coil packs to purchase for a 2001 roush gt with no power adder and quite a few bolt ons? I have been told weapon x coil packs are the best by a dyno expert is there any controversy?
Old 01-27-2010, 05:33 PM
Scrapper Scrapper is offline
AF Premium User
Re: Coil over plugs!!!!
you could try msd coils like the msd 2 coils your stock one may be only say around 15000v and the msd would probably put out 45000v. you might want to try this number and see the highest you can go? but the number is 1-800-913-6119.......good luck....
Old 01-27-2010, 05:45 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
MSDs are some of the best. But I've seen OEM Motorcraft COPs work just fine with blower applications pushing 450HP.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 03-26-2010, 04:01 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Either is fine, I would go the cheapest myself. Don't believe the hype.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
