Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-27-2010, 02:48 AM
xsbc63x xsbc63x is offline
04 maxima sl fuel smell in car
got a fuel smell in/outside the car with it running, more noticable while idling. hot or cold any time the blower is on fresh and it stops when you put it on recirc. also the fuel milage seems to be worse. NO CEL so im assuming that's clearing out any issues with evap. I checked it for fuel leaks and i see nothing. anyone have any ideas? no running issues, no smoking etc. just the smell and a little worse milage. maybe an injector ?
Old 01-27-2010, 07:38 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 04 maxima sl fuel smell in car
If u can smell gasoline, that comes only from vaporizing fuel. When engine is running & fully functional, the only way possible is a leak from fuel system...
If small amount of gasoline leaks on hot engine, it vaporizes instantly w/o a trace. Long time leak collects visible dust pattern around/down from the leak spot. Can be hard to locate. Taking pictures via down-the-horse-barn-inserted camera/flash may open vistas not possible to see otherwise...
Check all rubber hoses by bending and tighten clamps.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-27-2010, 07:49 AM
ricebike ricebike is offline
also, check the fuel injectors another tell-tale are brown spots where the injector meets the intake manifold
they can be leaking at the fuel rail to the individual fuel injectors... o rings on my nissan had dry-rotted on 2 of my 4 fuel injectors and i just replaced all of them for piece of mind... (this was on a 240sx)
Old 01-29-2010, 12:22 AM
consultIII consultIII is offline
agree with the other posts. only thing i can add is concerning evap and ses light. the evap monitor may not run if your driving conditons don't meet requirements to run the monitor...ie. short trips, starting after a hot soak, fuel level over 3/4 or under 1/4 tank...etc.
wonder if a fuel pressure leakdown test would show anything??
Old 01-30-2010, 12:22 AM
i did some checking on the car finally, and it looks like both the fuel dampers have dirt and debris stuck all around them so im guessing thats where my problem is, i am replacing them this weekend.
Old 01-30-2010, 02:48 AM
Can you tell where the leak suspect/soot sits... dampers?
