Old 01-26-2010, 06:35 PM
armbrust43 armbrust43 is offline
Clutch Problems
I just got a 2002 Cavalier 2.2 litre 5 speed the clutch is not working and it seems to be a different problem than everyone else is having. I have bled the clutch many times and it works for about 5 minutes and then it gets air in the system and the pedal sticks to the floor the thing that is confusing me is that it doesnt loose fluid the only time the fluid goes down is when i bleed the system so it is just sucking air and not leaking fluid i dont know what would cause this because i am not real familier with hydraulic clutch systems like these so any information would be appreciated thank you for your time
Old 01-26-2010, 09:35 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Clutch Problems
On brakes, I have seen the seal on the caliper piston will let air get sucked in, only seen it once. You may have a similar problem with your slave cylinder.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
