Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-26-2010, 07:27 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
18in rims vs speed
Will 18's make a big difference in the cars pick-up/speed? My car has hardly any power. I can put the pedal to the floor and it slowly creeps. Like I said in other post's, the engine has been rebuilt.
All sensers are new. Gaskets new. Bought new IAC just haven't had time to put it on yet. Didn't buy new vacum lines though. Where is all my power? Was thinking it could just be the 18's?
Old 01-26-2010, 07:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 18in rims vs speed
Depends on the rim weight. Normally 18" wheels do slow your car down some. It shouldn't be a huge amount, but it is more rotational mass that the car has to accelerate. Im guessing you have a 420a motor and auto tranny. The 420a motor doesn't have much power anyways but coupled with an auto tranny just makes it that much worse. If the car didn't use to be that slow the motor may have a problem. Is the motor stock? intake? exhaust?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-27-2010, 10:05 AM
Just an aem air intake and apexi pipe. The rims are motgei's not sure if any1 knows the weight on them. Last night when I took off it felt pretty good. IM just not my be use to the car yet I guess.
Old 01-28-2010, 12:34 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
My 16" Motegis were beasts (as are all cheap wheels). I shudder to think of the unsprung weight 2 more inches would add.
That said, putting the "pedal to the floor" and having the car "slowly creep" is not due to your rims.
Kris
2012 Genesis Coupe 2.0t
Old 02-11-2010, 01:20 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Sorry, that just means your car is slow. Rim diameter isnt too important but the overall weight is. A "light" set of 18's will weigh in around 20-22 lbs im sure yours are more. A set of 17" BBS rims will run you a small fortune because they are super light aka they are fast. As a general rule of thumb lighter, smaller diameter wheels will almost always make your car faster. But in your case its probably not the wheels's fault your car is slow, they just dont make a lot of power.
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
