Old 01-26-2010, 04:39 PM
syrjr1 syrjr1 is offline
DTC 301 code
I've been getting the code 301 which is misfire #1 cylinder. I pulled the #1 spark plug and wire. The plug was fine and the wire checked out fine. I cleared the code. 5 miles down the road the code sets again. So I inspected the ignition system from the coil to the spark plugs and found a severely corroded connection on the dist cap center connection and coil wire. I replaced the cap, rotor and spark plug wires and cleared the code. Two days and 30 miles later (yesterday) the code shows up again. This time I rebooted the computer by disconnecting the battery. I only drove the car to work (10 miles today) and no code yet. I don't feel like i've found the problem though. I need to make a 500 mile trip this weekend and i'm not feeling too good about it. Could this be an indication of the EGR passage plugging? Any thoughts you have would be helpful.
Thanks, Ron
97 1.0 137,000 miles
Old 01-26-2010, 07:03 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: DTC 301 code
If you have spark and fuel an #1 is still missfiring, then you need to perform a compression test. Here is a guide..............
http://geometroforum.com/topic/2574993/
Old 01-26-2010, 07:05 PM
Re: DTC 301 code
Compression is fine. The problem is electrical.
Thanks, Ron
Old 01-26-2010, 07:11 PM
Re: DTC 301 code
Thanks, Ron
You need spark, fuel, and compression for a cylinder to fire. Fuel is supplied to a 1.0 via throttle body, so if it runs, it's not fuel.
If you said the spark plug and wire is fine, then you have spark.
This means you do not have an "Electrical Problem"
Start the car, put on a glove, and remove wire #3. Is it sparking? Engine running really shitty? Repeat with #2 and finally #1. If removing #1 changes nothing, then either perform the compression test or throw parts at it.
Old 01-26-2010, 07:32 PM
Re: DTC 301 code
I'm telling you that the compression is fine. I did check it. Even the factory shop manual does not mention lack of compression as a cause for a DTC 301. The misfire is not caused by lack of fuel or compression. It must be electrical.
Old 01-26-2010, 07:42 PM
Re: DTC 301 code
Lemme know when you find your electrical problem.
Old 01-26-2010, 11:16 PM
brivers brivers is offline
Re: DTC 301 code
Your first post did not include spark plug replacement. Although your car could seem to run fine, the resistance across the air gap on spark plugs increases as your compression increases as in throttling up. A slight crack on the insulator of the plug can make high voltage go to ground before it reaches the end of the plug. To get that code it would not have to misfire 100% of the time, just a periodic miss that could go unnoticed could do it. Good luck.
Old 01-27-2010, 06:40 PM
Re: DTC 301 code
I replaced the plugs today just to eliminate them as a cause. The code came back within 30 miles of driving.
Old 01-28-2010, 03:42 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: DTC 301 code
That was the last thing left that could possibly be electrical. You've got a mechanical problem, most likely compression. Especially at that mileage, any G10 with 137K is suspect as far as burned valves go.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 01-28-2010, 09:21 AM
Re: DTC 301 code
The engine has about 60,000 miles since being rebuilt by me. Compression is 95-99 across the board cold. I've already said that compression is not the problem. It runs like there is nothing wrong. I'll have to check the gas mileage though to verify. EGR operates normally. Checked it yesterday. I'm starting to believe that there is no misfire even though the computer is indicating it. The PCM does not blink the check engine light first. It comes on solid and stores in memory. I'm going to check the wiring at the PCM today. Could be a loose or bad connection. The shop manual says that vacuum leaks, EGR, PCV, fuel pressure, defective crank timing belt pulley or poor connection at PCM could be the cause. That's alot of stuff... If I was able to collect freeze frame data when the code sets I would be better able to diagnose it. I don't have that kind of equipment. Evidently no one on this form has had this happen to them.
Old 01-28-2010, 08:20 PM
Re: DTC 301 code
Minimum Compression allowable in your manual is 155 PSI.
Old 01-29-2010, 04:23 AM
Woodie83's Avatar
Re: DTC 301 code
95 - 99 is a disaster, it's supposed to be 200 with 155 the factory recommended minimum, most cars will run down to about 100, but not well. You should certainly renew all electrical connectors and ground points, and check the timing belt lower pulley for make sure it's not slicing the woodruff key and walking around the crankshaft, but nothing that you've listed there would explain why it's reporting a cylinder 1 misfire rather than a general misfire.
Here's what my shop manual says, perhaps yours is missing an entire page on mechanical causes for this code:
Worn or faulty camshaft
Leaky or stick valves or rings
Excessive valve deposits
Weak valve springs
Malfunctioning Hydraulic valve adjusters
Incorrect valve timing
Intake (vacuum) leaks
Leaking head gasket
Loose or broken motor mount.
Yes, many of us have seen this problem, it's usually a bad spark plug wire or a burned valve.
Woodie
Old 01-29-2010, 09:47 AM
Re: DTC 301 code
My bad. The compression is 195-199 cold. Forgot the 1. I took out the PCM yesterday. I saw no evidence of corrosion on the terminals. Removed and reinstalled the plugs several times. The code reset again at after about 50 miles. Cleared the code and left the reader plugged in while driving about 10 miles. I constantly checked for codes while driving. the 301 code would come up then go away then come up then go away while I was cruising. The light did not come on though. When the light has come on and I read the codes it always shows the code being set twice. Guess i'll have to check the crank gear for dirt. Probably tomorrow. Again the car runs fine and pulls as hard as it ever has. The plugs I replaced looked identical in color.
Old 02-02-2010, 11:54 AM
Re: DTC 301 code
Removed the crank position sensor and inspected the trigger plate etc. I found nothing wrong. Area is dry and clean. Checked wiring to the sensor plug and found nothing abnormal. Checked EGR valve and found nothing wrong. Checked for intake leaks visually. Nothing apparant. Test drive shows the same symptoms as before. 301 code still comes up occasionally and goes away while continuously checking for codes during driving. It can come up while cruising or stopped and idling. Engine light does not come on until misfire is detected twice. Again the car runs fine and pulls as hard as it ever has. Idle is good. I'm not sure what to do next.
Old 03-03-2010, 11:24 AM
Re: DTC 301 code
I may have found the problem. I was checking the EGR valve and solenoids IAW the service manual. The EGR vacuum solenoid resistance checks out ok. The blow test, according to the service manual, does not pass. When blowing air into tube A (#2 in the illustration) the air blows out of the filter not tube B (#1 in the illustration). When I connect 12 volts to the solenoid the valve shuts and does not let air pass through at all. The EGR valve and the other solenoid check out ok.
