Old 01-26-2010, 02:08 PM
rickisrad rickisrad is offline
Abs
Is there a way to eliminate abs on the 98 windstar 3.8? I do not want to replace the Electronic module, it is comming up with the internal relay fault. I thought about putting a non abs master in it, but if there is a way to disengage the abs I would rather do that.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 01-26-2010, 07:44 PM
wiswind wiswind is offline
Re: Abs
If the ABS light is lit, the ABS is disabled.
I am guessing, if you are coming up with a fault, that the ABS light is lit?
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 01-26-2010, 08:31 PM
Re: Abs
no actual abs light. when the car slows down almost to a stop the abs kicks in for a second like when sliding on ice. I put the scanner on it and it had the internal relay fault, I cleared it and it came back. I have repacked and adjusted the rear bearings, checked the rings and all teeth are there. sensors look ok. I am not comming up with any specific wheel trouble codes. All four tire speeds are reading the same. I want to find a way just to disable the abs from kicking in or eliminate it all together. All the ABS fuses and relays are linked with other functions on the van or are internal. I was just going to unplug the actual abs unit and see if that has any effects.
Old 02-01-2010, 07:26 AM
mamato mamato is offline
Re: Abs
In my '96, there is a large fuse in the box under the hood that powers the ABS module. I was having similar problems several years ago and pulled the fuse. It has disabled the ABS function of which I am not a big fan. The only downside is that the ABS dash light is now on all the time, but I have gotten used to it.
Old 02-28-2010, 07:56 PM
Re: Abs
I pulled the fuse and relays but they all effected other systems on the car. I just went ahead and unplugged the abs unit itself and it completely disabled the abs. Stops great now.
