Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 01-26-2010, 06:12 AM
plancor plancor is offline
bulb change 99 300m
How miserable is it to change headlight bulbs in a 1999 300m . I have been told you have to take the front grill and stuff off?
Old 01-26-2010, 08:34 AM
tinmanwpk tinmanwpk is offline
Re: bulb change 99 300m
I believe you are right. You have to remove the front bumper assembly.
TinMan
99 M Cypress Green, performance rear sway bar, Brembo rotors w/CT3 pads, tint, Sirius, K&N intake, debadged, many other mods.
Old 01-26-2010, 09:40 AM
intimadatorsquizz intimadatorsquizz is offline
REMOVAL
  1. Release hood latch and open hood.
Access Rubber Grommet
  1. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
Fastener Locations
  1. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
Remove Push In Fasteners
  1. Remove the push pins attaching the fascia to the upper radiator closure panel.
Headlamp Jackscrews
  1. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
Roll Fascia Forward
  1. Roll fascia forward to clear way for headlamp housing removal.
  2. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
Remove Headlamp Housing
  1. Remove headlamp housing. INSTALLATION
CAUTION</B> : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Place headlamp housing into position.
  2. Connect wire connector to lamp socket(s)
  3. Verify headlamp and signal lamp operation.
  4. Install jackscrews to attach headlamp housing to crossmember.
  5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
  6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
  7. Install nut on fascia stud through the splash shield access hole.
  8. Verify headlamp operation and alignment.
Old 01-26-2010, 11:48 AM
o boy sounds like fun thank you for the help
Old 01-26-2010, 12:10 PM
no problem good Luck
Old 01-26-2010, 01:24 PM
It's not hard, it's just a pain...
I just wish we could get to that engineer who "designed" this getup.
TinMan
Old 01-26-2010, 02:50 PM
I'm sure by the time i get through i'll be screaming and running down the road tearing my clothes off lol
