Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-26-2010, 06:04 AM
drvitforever drvitforever is offline
'94 pickup problems with rain
My '94 pickup has idling problems in the rain. Seems like something gets wet, the idle slows like it's going to stall. Yesterday, it did. I was able to start it again, then it ran okay. I made 2 more short trips, then, when I started it, the check engine light came on. I had spark plug wires/dist. cap changed, and engine tuned up. Any other ideas? Thanks.
Old 01-26-2010, 10:27 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: '94 pickup problems with rain
Could be one of the many sensors is getting wet. The CEL may be giving you a clue, check the ECM for error codes. If you search you will find the instructions.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-26-2010, 07:10 PM
fasttoyotapu fasttoyotapu is offline
Send a message via AIM to fasttoyotapu Send a message via Yahoo to fasttoyotapu
Also depending on your engine type, your dist. cap may had a o-ring or gasket. Next time when your engine gives you troubles pop off your cap and see what's going on under there. if it's wet, it'll cause a misfire and trip your check engine light.
91 Toyota Pickup - Lowered, Racing Suspension, 96 Toyota Supra 2JZ-GTE Engine w/ 6 speed man. trans. - Crashed racing SCCA - RIP
86 Toyota Pickup - 4x4 - Chevy 305 Engine - Rest stock toyota
Current Project - 90 Toyota Bedless Pick-up - My new mini - Currently Lowering and finding a new bed. The flat bed went to my dad's truck. Merry Christmas Dad!!
Worked:
Doxon Toyota - 4 years
Bowen Scarff Ford and Scarff Ford- .5 years
