Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-26-2010, 06:03 AM
LEM LEM is offline
1990 LX 5.0L Heater Problem Fixed!
I found and fixed the heater problem I described in the post "90 LX 5.0L Low/No Heat and Radio Display Issue". The lack of heat was the result of low coolant level which was caused by a leak in the timing chain cover gasket. At first I thought the leak was coming from one of the small hoses on the water pump, but upon closer inspection I found water trickling from behind the water pump. I then thought that I had a cracked block, thank God it was just the gasket. Took me a day and a half to replace it, replace the thermostat, replace the water pump, change the oil, and flush the coolant system; but now I have good heat and no gurgling noise!
Thanks.
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...
-2005 Yamaha V-Star 1100 Custom
-2008 Toyota 4Runner Ltd 4.7L AWD
-2019 Subaru Ascent (the wife's)
