Old 01-25-2010, 05:04 PM
stevec66 stevec66 is offline
s-10 wont start now
my engine in my s-10 was running bad the other day so I noticed it was a spark plug wire was bad I put new wires on and rode it down town and it ran great..i go to get in it today and it wont start..It will crank but no start...I ended up putting a lil bit of gas in the throttle body and it still wouldnt turn over..its a 91 4.3 chevy s-10 and Im laid off and dont have much money..i just need to find a way to get this beast running again....help!!
Old 01-26-2010, 09:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: s-10 wont start now
Does engine crank over good?
Did it have any codes or check engine lights when it was running?
FIRST CHECK FOR LOSE OF SPARK OR LOSE OF FUEL PRESSURE.
Let us know if it is losing spark or fuel pressure.
Check for good hot spark to all plugs.
Check for fuel pump running and fuel pressure.
Do you hear fuel pump on key on 2 second engine/fuel pump prime up?
MT
Old 01-29-2010, 06:49 PM
82Stang 82Stang is offline
Just a side note to MT. You could also check to make sure the wires you ran were routed away from the manifolds and are not burnt.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 02-23-2010, 12:17 PM
colbra colbra is offline
Also check your fuses
