Old 01-25-2010, 04:28 PM
Danny M Danny M is offline
Tccm
I was hoping somebody could tell me if they know of any place that has Aftermarket Transfer Control Case for 2000 Blazer. I am in Oakville ON I am willing to travel some if the price is right or does anybody know where there is a usesd on. Thanks
Old 01-25-2010, 04:50 PM
old_master's Avatar
Advisor/Moderator
Re: Tccm
What problems are you having with 4WD? There are other, more common, things that fail.
3 button manual 4WD or 4 button Auto 4WD?
You have to know how it works,
to figure out why it doesn't.
Old 01-25-2010, 05:00 PM
Re: Tccm
One wire was full of corrosion on the plug . But then the plug attached to the module itself has one pin broke off I have a 4 button switch
Old 01-25-2010, 05:42 PM
old_master's Avatar
Advisor/Moderator
Re: Tccm
I see... call around to some boneyards in your area and see if they have a TCCM.
Old 01-25-2010, 06:26 PM
Re: Tccm
I have been checking around so far no luck. That is why I was wondering if anybody knew where to get an aftermarket. The dealer wants 1000 for one. The whole problem started because I was having trouble going into 4x4 Whenever I pressed auto it would go to 4hi then I would have trouble getting back out. So I decided to check the wires that is when I seen this problem. I hope this will fix it once I get a new one. Also the service 4wheel drive light was coming on.
Old 01-25-2010, 06:35 PM
old_master's Avatar
Advisor/Moderator
Re: Tccm
Here's one for less than $1,000
http://stores.channeladvisor.com/Aut...LAID=443946607
Old 01-25-2010, 07:35 PM
Re: Tccm
Thanks I sent them an email to see if they have the right ID number for my Blazer. One other problem I just realized is when I cut the old plug off so I can splice the new one on I seen that some of the wires are the same colour. How do I know what wire goes to what?
Old 01-25-2010, 07:47 PM
old_master's Avatar
Advisor/Moderator
Re: Tccm
On the rear of the transfer case there is a round tag, it will tell what model transfer case you have. It will be either NVG233 or NVG236. If you get me that information, I can get you a PDF of the schematic and email it to you.
Old 01-25-2010, 08:02 PM
Re: Tccm
Ok I crawled un and seen a number it says 236GM Will the schematic show which wires from the vehicle go to the plug even though some are the same colour. I really appreciate your help
Old 01-26-2010, 03:24 PM
laxman21's Avatar
laxman21 laxman21 is offline
Re: Tccm
GEt on EBAY..$100 for them. Any you pickit yards around you? I got mine from one for $10.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 01-26-2010, 03:55 PM
Re: Tccm
Every wrecker I have been checking doesn't have any. Or they say they might be able to find one for around 350
Old 01-26-2010, 03:56 PM
Re: Tccm
I looked on ebay nothing there for mine
Old 01-26-2010, 03:59 PM
Re: Tccm
Do you know if it is possible to fix the pin on the TCCM maybe by solder?
Old 01-26-2010, 08:47 PM
old_master's Avatar
Advisor/Moderator
Re: Tccm
Try it, ya got nuthin' to lose, it's no good the way it is!
Old 01-28-2010, 02:33 PM
laxman21's Avatar
Re: Tccm
What is the part # you need? There are updated numbers.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
