Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-25-2010, 01:11 PM
scoopy03 scoopy03 is offline
84 regal t-type backfiring in BRAND NEW turbo
I put on a new turbo on the car because the last one on it had the same problem and burnt the turbo up. The backfiring is still occuring. Firing order is correct. Have checked it atleast 10 times. Have checked spark plugs and changed them a few times after they keep getting loaded up with fuel. What could be the cause of the backfire?
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 01-25-2010, 10:38 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 84 regal t-type backfiring in BRAND NEW turbo
Time for a leak-down & compression test to to see if the problem is the timing chain, burnt/bent valves, worn cam lobes, or fuel related issues.
Old 01-26-2010, 03:08 PM
Will let you know the outcome.
