Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-25-2010, 10:13 AM
gatorbite2 gatorbite2 is offline
4x4 Service Light
i have a 2000 GMC Jimmy 4x4 and the 4x4 service light came on after reading a few post i decided the first step would be to replace the switch
after replacing it now it went to 4 high and wont go out everytime i try and switch it to 2 wheel drive it makes a clicking noise under the passenger side of my dash but wont switch into 2
i put the old switch back in and it does the same so now i went from 2 wheel before i replaced the switch to 4 wheel and and cant get it out
maybe the module ?
any help would be nice
Old 01-25-2010, 04:55 PM
old_master's Avatar
Advisor/Moderator
Re: 4x4 Service Light
Are all 4 tires the same brand and size and is tire pressure equal in all 4 tires?
Does the actuator under the battery tray have vacuum to it when you switch to 4WD?
Does the actuator under the battery tray pull the cable at least 1/2" when you switch to 4WD?
You have to know how it works,
to figure out why it doesn't.
Old 01-25-2010, 06:42 PM
yes the tires are all new and air pressure is the same at 32
ill take a look at the actuator in the morning
Thanks
Old 01-25-2010, 07:10 PM
Danny M Danny M is offline
I am having the same problem and I found a broken wire on my module I cut the old plug off and figured I would splice the a new one to the wires but now I just realized some of the wires are the same colour so I don't know how I am going to splice it now. Any advice?
Old 01-30-2010, 05:03 PM
sorry it took so long to get back to all this was out of town
the fix for mine was encoder motor decided to just take it into a garage my family deals with and was a pretty easy fix
Thanks
Old 01-30-2010, 05:13 PM
Was it very expensive to have fixed? How many hours of labor did he charge
