Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 01-24-2010, 02:31 PM
DonSor DonSor is offline
Running Light
I installed a front running light in my '99 Ranger XLT using a relay activated by the oil pressure switch. When I turn the ignition on, it activates the relay and turns the fused running lights on. However, I also want to have running lights for the rear so others can see me from behind. Installing two red light fixtures in the rear seemed impractical so what do you think of this idea. I will use my tail lights also as running lights. Using a pair of diodes, I will run a set of wires to the rear of my truck and tap this in to the tail light wires. The diodes will prevent backfeed.
From the main light circuit + ------->| (diode)----!
!------Tail light
From the running light circuit + ------>| diode)-----! (ground)
Will this work?
Old 01-24-2010, 02:35 PM
Re: Running Light
Correction! My diagram did not come out as I made it. But you can figure out the two hots going to the same element via respective diodes.
Old 01-25-2010, 12:31 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Running Light
I think that will work. Give it a try.
