Old 01-24-2010, 11:18 AM
thunder42 thunder42 is offline
headlights and drl don't work
2001 sunfire the low beam and drl lamps don't work.high beams are ok.checked fuse block and fuse cluster and changed relay. plase help
Old 01-24-2010, 12:52 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: headlights and drl don't work
Make sure the bulbs are good, they have separate filaments for low/high beam, it's rare but they could have both burnt out at roughly the same time. Check for power at the connector, if you don't have it, check the wiring harness. It's somewhat common for the wires to corrode and open.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-24-2010, 01:55 PM
just finished a little test drive i notice when i put the car in drive the lights flash about 5 times then a service light with a wrench comes on in the dash if i turn high beams on then put it in drive its ok
Old 01-24-2010, 01:59 PM
jd-autotech jd-autotech is offline
that service light indicates a bulb out
Old 01-24-2010, 02:23 PM
thankyou i will change both bulbs
Old 01-24-2010, 03:16 PM
changed both headlights stil the same flashing
Old 01-25-2010, 11:30 PM
TheDevilIKnow TheDevilIKnow is offline
Did you look at the DRL module? I believe Body Control Module is also involved in this circuit. Time for a DRB Diagnostic to see if you can save some time and grief. Should be a trouble code registered if the little wrench is flashing. Need those headlights!
Old 01-26-2010, 06:12 AM
J-Ri's Avatar
It's implied with "check for power", but also check ground. A number of people have have had this problem, a quick search should give you the location that usually fails.
BTW, DRB is the Chrysler factory scan tool... You'll need a Tech-2 to check codes on your GM.
