Old 01-24-2010, 10:00 AM
walker12 walker12 is offline
whistling sound coming from engine
ok i have has a whistling sound coming from my engine for a while now.
its really noticable when its cold out and when i get on the gas.
im thinking maybe a cracked vaccum line or intake hose?
if anyone has an idea of what this could be let me know thanks
Old 01-24-2010, 01:01 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: whistling sound coming from engine
You're probably right about it being a vacuum leak, take a look/listen and replace any leaking hoses. I have also seen bad throttle body gaskets cause this.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
