Old 01-24-2010, 06:31 AM
gumby_ct gumby_ct is offline
Water Pump @106k
The water pump just stopped pumping and leaking at 106k mi. I am just wondering when others are finding that their water pumps fail?
Yes, I will be doing the Timing Belt too, while I am in there. It looks like the Timing Belt has never been done before. What is the scheduled interval for the timing belts? The 1.0L is a non-interference engine, I hope?
Well gotta get busy before the BIG flash flooding rains get here.
1998 Chevy Tracker 4dr, 4wd, auto,
1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi.
My other car...in need of repair it won't start any longer
1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav)
Old 01-24-2010, 08:21 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: Water Pump @106k
Non Interference, although I find that the cessation of operation interferes with my life in a big, big way. Newer timing belts (I think 95 is when they changed) are rated for 90K miles, the old ones were 60K. I'd say 100K is about average for a water pump, but it varies drastically, hard to name an exact number. The key point is that it's almost the exact same job to replace the water pump as it is the timing belt, to do one without the other is folly.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 01-24-2010, 08:45 AM
Originally Posted by Woodie83 View Post
Non Interference, ... The key point is that it's almost the exact same job to replace the water pump as it is the timing belt, to do one without the other is folly.
Oh I agree. Just got the timing belt OFF and it is in remarkably good condition.
The timing and alternator belts also cost about the same. Tho the alternator belt is grossly cracked and definitely needs replacing.
I think the hardest part so far was getting that blasted front wheel OFF.
Old 01-24-2010, 04:32 PM
Ok done with that. Started right up, so I musta done something right
Will have to see how the next couple days go to see if the head was warped or damaged by her driving it this way. ooops.
106,629 miles
new timing & alternator belts; new water pump; air filter & oil changed. Battery was changed 12-29-2009 (2nd battery, too)
Old 01-25-2010, 04:56 AM
Woodie83's Avatar
Nicely done. Your alternator belt isn't tight enough though. How do I know? No Metro has ever had it's alternator belt truly tight enough. They usually require a bit of a tweak after 100 miles on a new belt.
Woodie
Old 01-25-2010, 09:28 PM
Actually, I followed this guys advise and didn't have any problem
http://www.automotiveforums.com/vbulletin/showthread.php?p=3871630#post3lems871630
Originally Posted by gumby_ct View Post
I 3rd what Crvett69 & 3M said...mine squealed til I tightened the belt.
Put a socket on the alternator (ENGINE OFF & in neutral), turn socket 5-6 complete revolutions. If you can't turn the crankshaft - you found your problem. Get a Big screwdriver or prybar - tighten belt again.
Good Luck,
Gumby_CT
