Need Help with p0410 check engine code
I just had my heater hoses replaced and within 15 miles of leaving the shop I got a check engine light with and a PO410 Code. I suspect the mechanic dislodged some fitting or connection when making the repair. What should I be checking for? This is the first time I've ever had this code come up.
Re: Need Help with p0410 check engine code
There is a few hoses, pump, electrical components, etc. to check. Personally, if the engine was running fine before the work was done I'd return to the shop and ask to have him check it over.
The problem with doing nothing is not knowing when you're finished. |
It sounds like sabotage, check for a loose connector, or bad fuse.
