Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-23-2010, 09:30 PM
drgn4u2c drgn4u2c is offline
98 Lss , HELP PLEASE HEATER PROBLEM ...
I have a 98 Lss with 3.8 . Info it has the auto digital and pass temp control , The blower works great , With both settings on hot the heater has a mind of its own . It blows cold no matter what with car up to reg temp . when and if its decides to start blowing it blows little warm ait from the drivers side . and some times it will work its way over to pass side and then the heater works great like its spose to . till you turn the car off . and some days is never blower warm or hot air just cold . I have a Baby girl and need HEAT thanks . Also i have hot coolant going in to heater core and coolant if full .
Old 01-24-2010, 12:32 AM
Hmanor3 Hmanor3 is offline
Re: 98 Lss , HELP PLEASE HEATER PROBLEM ...
Assuming the cooling system is working properly, and you have hot coolant into and out of the heater core, that would indicate the problem is inside the dash. The ’98 Olds LSS is equipped with a dual zone Automatic climate control unit. The main component in this system is the programmer unit. This unit, located behind the glove box, controls the temperature, and air discharge locations. There may be problem with this unit causing your issue. But before we assume this is the problem we should check the air valve temperature actuators. There are two of them, one for the driver’s side, and one for the passenger side. One is located on top of the programmer, and one inside the programmer case on the bottom. There will be a small threaded rod attached to each of them. To check them, warm up the car and turn the temperature control down to 60, wait 10 seconds, and turn it up to 90, and look to see if the actuators are moving. One will move with the passenger control, one with the dash control, unless the passenger side is turned off, then both should move together. I would start there. They are known to stick.
Old 02-02-2010, 08:32 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
couldn't have said it better myself
