Old 01-23-2010, 04:51 PM
brucehe brucehe is offline
College Truck
I have a '2000 Ford F150 with a used engine. Two igniter coils were replaced. Recently, engine would crank but not start. Friend kicked the gas tank and truck started!? This scenario happened several times. Now it starts but runs rough while accelerating. At idle, and while cruising, seems to be smooth. Could this problem be the fuel pump or possibly more igniter coil problems.
Thanks, Bruce
Old 01-23-2010, 08:11 PM
danielsatur danielsatur is offline
Re: College Truck
Did you replace the fuel filter yet?
Old 01-24-2010, 06:56 PM
Re: College Truck
Yes, it has a new fuel filter.
Old 01-24-2010, 07:27 PM
Re: College Truck
Need todo a fuel pressure test.
Old 01-24-2010, 07:58 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: College Truck
Based on the effect kicking the fuel tank has, I'd lean towards a fuel pump problem. Either a weak pump or a loose connection...or both.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 01-24-2010, 09:00 PM
Davescort97 Davescort97 is offline
Escort guy
Re: College Truck
Maybe the inlet screen for the fuel pump was plugged. Kicking the tank might have opened it up a little bit.
