Go Back   Automotive Forums Car Chat > Nissan > Nissan Cima | Nissan President | Infiniti Q45
Old 01-23-2010, 02:44 PM
dawnnewsome3 dawnnewsome3 is offline
Angry Another bad Injector
I,m getting very tired of this car I had another injector go bad #3 right behind the front plenum runner, was able to fish it out with out removing the intake. Is this going to be a common thing until I replace them all? Should I just sell it? Also now I think I have a fouled plug as I tore a O ring on the install and it flooded the car on startup . It idles ruff from 1500 rpm to 2000 and this did not happen on the last installs. POS!!!!
Old 01-24-2010, 12:07 PM
maxnix's Avatar
maxnix maxnix is offline
Lightbulb Re: Another bad Injector
Much easier to replace injectors in rail once out of the car. Damaging O rings is common otherwise and hydraulic locking is a sure way to bend a rod.
There is a way to switch to the later rotary pintle injectors which are not so susceptible to ethanol if you have an earlier 1990-1993 G50.
Brian
1995 Q45 & Q45t 2000 Q45
