Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 01-23-2010, 10:14 AM
010175 010175 is offline
Timing engine by vacum?
1961 GM engine and i read that you cant time engine by a timing light because of new gas. True or Not? They said to use a vacum gage but how? Thanks Dave
Old 01-23-2010, 10:19 AM
maxwedge maxwedge is offline
A990 racer
Re: Timing engine by vacum?
Not true, set the timing to spec and drive it, under heavy load you may get a slight ping, normal. Worn timing chains and loss of compression on an older engine actually may allow slightly more base timing.
Old 01-23-2010, 04:49 PM
Thanks I will put a light on it.. Dave
Old 01-23-2010, 09:37 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Vacuum gauges are handy for setting carb idle mixture and for detecting faulty valve timing, but vacuum is not directly affected by ignition timing.
Old 01-23-2010, 11:05 PM
consultIII consultIII is offline
i agree that nothings more accurate that a timing light.
but to play devil's advocate....
my old motive power instructor (who was a ford master tech) told me he used to time certain older vans by vacuum as you couldn't get a light on the marks.
the procedure (if I remember correctly...which i may not) was to turn the distributor to achieve max vacuum and turn back so it drops 2" vacuum from max....or may have been max vacuum and turn back until get 50rpm drop?
comments
Old 01-24-2010, 11:47 AM
j cAT j cAT is offline
review this thread I posted in april of 2008. this chart is what you need to set up the timing for optimal performance...
the use of relead is needed when running these older engines..this should protect the valves from wear..
http://www.automotiveforums.com/vbul...d.php?t=897935
