Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-23-2010, 09:08 AM
BLRobertson BLRobertson is offline
Rocker arm torque
Dad's 2003 Century needs the LIM gaskets replaced so I've been reading anything I can about the procedure. My question is about setting up the rocker arm torque. The info I've seen doesn't mention rotating the engine to get the cam positioned to take tension off the pushrod. Most of my experience is with V-8s so these V-6 engines are all new to me. Thanks for the help.
Old 01-29-2010, 08:19 AM
Re: Rocker arm torque
Maybe I can clarify my question. Can the torque on the rocker arms be set with the crankshaft in any position?
Old 01-29-2010, 09:40 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
These engines are a zero lash design, so you don't have to rotate the engine to torque the rocker arms like the old days. I believe your torque value is 20 ft/lbs +30 degrees.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-29-2010, 11:20 AM
012620's Avatar
012620 012620 is offline
Hi I had the same questions about two years ago. Here is the link to the answers. Good luck.
http://www.automotiveforums.com/vbul...d.php?t=886223
Old 01-31-2010, 08:40 AM
Thank you both for your reply.That has answered my question plus some helpful tips.
