Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-23-2010, 12:56 AM
j.rok j.rok is offline
95 z28 fuse block 2 93 z28 swap
i have a 93 z28 i obtained and the inside wiring harness was trashed
i got a 95 z28 fuseblock harness plugs all matched except a couple of wires here on the fuel pump, and where the key switch turns it was missing 2 wires also does n e body know if and or how to make this one work? if possible and it has the obd2 plug.
after i plugged it in it turn the car over,had no spark,fuel pump would not kick on and the scanner i had would not read the comp. there must b a couple of wires to move and a plug or two to change but pls, need info!
