Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-21-2010, 02:56 PM
turfking turfking is offline
'93 sierra spitting through carb
I just inherited a 93 sierra 1599 w/134,000 miles. It spits back through the carb/throttle when accelerating.Is this problem also causing a hard shift. Help before my wife makes me sell it!
Old 01-23-2010, 12:55 PM
2000CAYukon 2000CAYukon is offline
Re: '93 sierra spitting through carb
Is the check engine light on? Did you have it scanned? That will tell you if it is running rich or lean?
If it is really backfiring, then you need to check EGR valve, cap and rotor and ignition wires.
Is ignition timing set correctly? What is the fuel pressure? How is the compression?
//2000CAYukon
Old 01-25-2010, 06:03 AM
changed rotor,dist. cap,plugs and wires. running better but now i have to get the oil dipstick off of number 3 cylinder spark plug. two knuckleheads somehow placed the tube between the ex.mani. and block and is laying up against the plug ,nice blue spark.
Old 01-25-2010, 06:20 AM
sorry,dipstick on number 4 cylinder shorting it out.
