| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
93 f150 straight 6 oil pan
hey all, just wondering what I have to do to change an oil pan on a 4.9l straight 6. I have been told that I have o jack up on the engine to remove it, is this true? I have also been old that on a straight 6 it isnt necessary to do that. which way is correct and/or easiest. thanks
Re: 93 f150 straight 6 oil pan
Are you changing, because of a bad pan or gasket?
A leaking pan can be fixed without removing. |
the pan has at least 25 holes in it in the curved part at the top so i need to change
i patched 6 months ago and the patch itself is holding
Yes you have to jack the engine up. A lot of steps to the procedure. I would suggest you buy a Haynes repair manual that covers the '93 F150. About 20 dollars. It gives step by step instructions.
is there no way to get the pan out without jacking the engine up?
It shouldn't be a real hard job if you follow the instructions in a manual for that vehicle. It would be a little time consuming though. |
