Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-21-2010, 01:06 PM
BostonKev BostonKev is offline
03 cvpi code p2197
Hi all, I have an 03 that keeps popping a 2197 code. I've checked for the obvious vacuum leaks around the hoses and the car runs perfect so I'm a but stumped. It comes on about once avery 4 days. Other than a smoke test or spraying carb clean all around the hoses, any suggestions would be appreciated. Thank you.
Old 01-21-2010, 02:11 PM
danielsatur danielsatur is offline
Re: 03 cvpi code p2197
DTC 2197 - Sensor signal stuck lean (Bank 2, sensor 1).
Was this H02 sensor replaced?
Also look for a damaged H02 sensor wire on bank 2 (cylinders 5-8) , the upstream HO2 sensor 1 is the one befor the cat.
Old 01-21-2010, 03:08 PM
02 sensor was not replaced but the pass side manifold gasket was recently.
Old 01-21-2010, 10:42 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Of the manifold gasket was recently replaced, it's possible that there is a leak in it giving a false lean condition to the H02 on this side. Alternatively, the sensor may just be going bad. See if you can get your hands on a scan tool that can monitor O2 outputs. It should be switching rich/lean.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
