Old 01-21-2010, 07:01 AM
shanes76 shanes76 is offline
94 Jimmy motor mount
I think I have a bad motor mount on the drivers side, can I just jack up the motor a little and swap it out? IS it a rough job to do? I can put it in drive and with my foot on the brake rev it up and watch the drivers side of the engine raise a few inches, seems more than normal to me
Old 01-21-2010, 07:18 PM
old_master's Avatar
Advisor/Moderator
Re: 94 Jimmy motor mount
If it's 4WD it's a rough job. If it's 2WD it's a little easier but still no fun. I don't think I'd try it without a hoist. The jack stands will always be in your way.
You have to know how it works,
to figure out why it doesn't.
Old 01-21-2010, 07:46 PM
I thought maybe I could lift it up enough with a jack and get a new one in, without using jack stands
Old 01-21-2010, 08:01 PM
old_master's Avatar
Advisor/Moderator
Take a look in there, there is virtually no room to work. Even on a hoist you need to be a contortionist to get at it.
Old 01-21-2010, 08:05 PM
well I dont have a hoist, soI pretty much dont have much choice other than do it that way
Old 01-21-2010, 08:33 PM
do you know how many hours a shop will charge for this? I have a shop close to my house and they charge 55.00 an hour for labor, but was wandering how many hours it says in the book they use (the one that tells them the hours or something)
Old 01-21-2010, 08:39 PM
old_master's Avatar
Advisor/Moderator
I don't have a flat rate manual handy right now but I think it's probably in the neighborhood of 3 hours.
Old 01-21-2010, 08:46 PM
would that be for both sides or just one side? Did you see the post a I after I replaced the fuel nut lines?
Old 01-21-2010, 09:05 PM
old_master's Avatar
Advisor/Moderator
That's per side, and yes I did.
Old 01-21-2010, 09:23 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Why do you suspect bad motor nounts? Can you see that they are bad? Please describe your symptoms. Typically, it is the drivers side that goes out first because that is they way the motor torques.
Here is one way to tell. Set the parking brake, Start the truck and shift to drive, with both feet hard on the brake pedal, then with the hood open and someone watching the engine, slowly rev the engine DO NOT GUN THE ENGINE. If your motor mount is broken, you will see the motor rise up off of the mount. If this happens, stop the gas and shut off the engine IMMEDIATELY. Do not let the engine rise too far up or your fan will hit the fan shroud and could cause more damage.
Old Master is right. I did my '93 in the driveway with jack stands and a floor jack. It is a real bitch. I think I had about 4 hours into it by the time I got finished. You will need two people, a good selection of wrenches, sockets, long extensions and a lot of patience. I would suggest if you do it yourself, do it one side at a time. Diconnect the battery because the passenger's side mount is right next to the hot lead on the starter, and you will arc out.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 01-26-2010, 06:58 AM
yeah I did the foot on the brake and gas thing, its a broke mount, I have a shop willing to do it for 50.00 and I buy the mount which is 20.00 so they have them selves a job! lol
Old 01-26-2010, 01:31 PM
old_master's Avatar
Advisor/Moderator
WOW, $50, better jump all over that one before they see it and change their mind!
