Old 01-20-2010, 10:00 PM
ezfive ezfive is offline
74 F100 Not starting now
Ok...Ive been driving my dent side around for awhile now. Was running fine (except the high idle cam that needs adjusting), anyway I drove to work shut it off came back a couple hours later and it wouldnt start. After multiple attempts at starting it fired up and was able to drive. Drove it a couple miles to an appt. Came out and same problem. This time after multiple starting attempts again I quit. The motor turns and has/gets fuel to the carb (I removed the air cleaner and opened the throttle and fuel squirted in). When I repeatedly press/depress the gas pedal it almost wants to start but no go. Spark plugs, ignition module, distributor, carb out of adjustment? Still a newbie and not a mechanic just a parts changer that enjoys older trucks so be easy please. Thanks all!!
Old 01-20-2010, 10:35 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 74 F100 Not starting now
I presume the choke blade closes when it should, right?
Pull a spark plug and test for spark. Pull a few more plugs and see what they look like. Are they dry and tan-color, or are they black and wet or sooty-looking.
Take a look under the distributor cap. Is it dry or damp? Your current weather conditions and driving habits are good for forming condensation under the distributor cap.
Also, is this truck electronic ignition? It may still be points.
Old 01-20-2010, 10:41 PM
danielsatur danielsatur is offline
It seemed like those older Ford trucks would flood easy!
Old 01-21-2010, 07:10 AM
I'll check the plugs this weekend. Yes it still has points, I want to change it to electric but havnt gotten to that on my laundry list of repairs/upgrades. I dont how to check if the choke is functioning correctly.
