Old 01-20-2010, 11:21 AM
sailor86's Avatar
sailor86 sailor86 is offline
Bad brakes?
Under normal moderate conditions, the brakes on my Galant ES work fine. But when I need to make a sudden stop, they make a grinding noise. I checked the pads and they're fine. I go to check the brake fluid and it's a little above minimum. I go to add fluid and I see this:
That thing with the X doesn't move. I'm guessing it's supposed to float or something. Is that right? And what do I do about it?
If it ain't broke, see how you can complicate it.
2002 Mitsubishi Galant ES 4 cyl Front-wheel-drive. Automatic.
Old 01-20-2010, 12:53 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Bad brakes?
The plastic mesh is just a strainer to keep the big chunks of contaminants out. It may or may not be removable, but you can pour the new fluid in and it will fall through into the reservoir.
Grinding brakes probably isn't caused by the low fluid, but you have to ask where the fluid went. My guess is you have a leaking brake caliper or drum brake cylinder. Look on the inside of your tires..if you see oily streaks radiating from the wheel's center that's where the fluid is coming from. The fluid has likely contaminated the pad/shoe surface causing the weird grinding noise.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-20-2010, 01:02 PM
sailor86's Avatar
Re: Bad brakes?
It was a false alarm. I just added brake fluid and everything's fine now. But thank you for taking the time.
Old 01-20-2010, 02:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Bad brakes?
I'm with JDMccright on this one, low fluid makes no sense for the symptoms you describe. And if the fluid level is low, it's low for a reason. The fluid doesn't just evaporate. You have an issue somewhere that needs to be addressed, and if you heard a grinding, you probably have worn friction material at one or more of the wheels. Did you remove all four wheels and carefully inspect all pads/shoes, or just try to peek through openings in the wheels to get a glimpse of the friction material?
-Rod
Old 01-20-2010, 03:28 PM
sailor86's Avatar
Re: Bad brakes?
Nope. I checked all four wheels and no sign of leakage. I don't believe I have ever added fluid so the level may have been where it was for some time. Whenever I checked, the level was above minimum so I left it alone.
Old 01-20-2010, 03:44 PM
sailor86's Avatar
Re: Bad brakes?
Should I open up my drum brakes and do an internal visual or are there other signs that should tell me when it's time to change/overhaul them.
Old 01-20-2010, 06:50 PM
RahX RahX is offline
Re: Bad brakes?
Your front calipers could be tweaking slightly and allowing the pads to contact the rust on the outside and/or inside of the normal contact area and MOST LIKELY is nothing to worry about. I'd say turning the rotors wouldn't hurt. Also adding fluid is not good unless it is really low. As the brakes wear the fluid in the reservoir naturally gets lower as well. It being near minimum could mean that you need front and/or rear brakes. It would probably be a good idea to have them checked.
Old 01-21-2010, 09:21 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Bad brakes?
Definitely have them checked, low fluid won't cause grinding. Typically, from "full" to "minimum" is about how much fluid the calipers hold (pistons move out as pads/rotors wear).
You either have a leak or the pads are worn out, as at least one of those statements has to be true.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-23-2010, 09:51 AM
jdmccright's Avatar
The RustBuster
Re: Bad brakes?
Thanks for the response but please check the thread's date to be sure you are not replying to a "dead" thread.
Also, spraying a brake rotor or drum with water while it is hot is a bad idea...warpage or even cracking of the rotor can occur. You are better off disassembling the brakes and cleaning the pads and rotor surface with a wire brush or rust removal wheel to dislodge any embedded dirt or heavy rust. Even cold it is difficult to get a good stream of water aimed where it needs to between the pad and rotor to do any good with all the other parts in the way.
It is possible the grinding sound was caused by the formation of rust over time when the car was sitting still. It will go away with a few applications of the brakes.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 07-23-2010, 06:18 PM
Re: Bad brakes?
The most likely cause of this is the rust ring around the outside and inside of the rotor where your pads have worn into the rotor a bit. The shiny part is where the brakes normally ride and is well worn, just outside of that is where i'm talking about. Normal braking doesn't load the caliper enough to get the pads into this region. When you really stop hard, the caliper tweaks just enough to get the pads into this area and it makes a racket. It does not take much rust to cause some pretty horrendous noises. It is nothing dangerous or abnormal. The only proper cure is to have the rotor machined or replaced. A quick and dirty fix that will only last a few weeks is to make several hard stops from 40+.
