Old 01-20-2010, 09:22 AM
shanes76 shanes76 is offline
? about seafoam
I was wandering what does sucking seafoam thru the brake booster line do? Will it go into my oil if I do? I read something about sucking half the bottle thru the brake booster line and dumping the rest in the tank. Just what exactly does this do?
Old 01-20-2010, 10:10 AM
laxman21's Avatar
laxman21 laxman21 is offline
Re: ? about seafoam
Cleans carbon deposits.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 01-20-2010, 11:26 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ? about seafoam
Seafoam was made for a gas stabilizer.
But like WD-40 they claim it does a lot of other things and used for a lot of other things.
Some good and some not so good.
As said some use it for cleaning carbon.
When installing/pour in intake pour it threw the TBI so it gets to all cylinders.
I would only use it to clean carbon if needed.
If not broke do not try to fix it.
Are you having any problems with the engine?
MT
Old 01-20-2010, 03:24 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: ? about seafoam
It actually works very well when used to clean the TB/intake/valves like you plan on doing, but like MT2500 said, don't use it for anything else. Using it in fuel doesn't hurt anything, but it cleans about as much as filling up with ethanol does. Never use it in the oil, it's mostly alcohol, not a good mix.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
