Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 01-19-2010, 10:48 AM
dave1356 dave1356 is offline
1993 pont,transport
i turned off car and about hour later tried to start it and it wouldnt start i checked plugs and had no spark changed coil pask and still no spark does any one have any idea what the prob might be
Old 01-19-2010, 02:58 PM
nicke66 nicke66 is offline
Re: Start check for codes
From another thread by "knuckle ears":
"You can get the Check engine codes on your 93 by jumping the A and B terminals located under the steering wheel and dash panel to the left. You will see a black terminal box. Put a wire between A and B with the ignition on but no start. The Check engine light will start to flash. A flash and then a pause and then 2 flashes means #12. This is normal and means the computer is working. There will be a pause and it will flash again 2 more times. If you have any other codes they will then come up, they will each flash 3 times like before. Record the codes and go to http://autorepair.about.com/library/...l-dtcs-36a.htm to see the results."
Post any result here and please tell what engine you have.
