Old 01-19-2010, 07:51 AM
jonnymerc jonnymerc is offline
speed-o & radio problems
First started a while ago. Radio would not shut off when doors were opened and keys were out of ignition. Just last week, radio actually turned back on by itself when truck was parked for a while!!!! So, I disconnected the battery and reconnected when we left a couple days later(we were fishing up the gunflint) When we took off that morning, the speed-o read 25mph while we were idling. after stopping for gas and shutting truck off, speed-o went down to 10 mph while idling. Any information would be greatly appreciated. No check engine light has come on or anything else. Truck seems to run fine, other than this.
Old 01-19-2010, 07:52 AM
Re: speed-o & radio problems
oh, 2004 Chev 2500HD with 6.0 4X4.
Old 01-19-2010, 02:17 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Not sure abt the radio (which is junk IMO), but the speedo problems may be faulty stepper motors in the cluster...common problem for alot of GM vehicles 2002-2005. You can send the cluster out and have them all replaced with an updated design for abt $75 plus shipping. Did my Envoy's through an eBay repairman.
All I can think of for the radio is a faulty ignition switch...many vehicles let you listen to the radio for ~15 minutes after removing the key. That or there is a relay that controls the delayed-off feature. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-23-2010, 04:49 PM
Jeremy-WI Jeremy-WI is offline
The radio might be junk, it is hooked up to the speed sensor circuit for the speed controlled volume, it may be back feeding the circuit. I would remove the radio from the dash and see if the problem disappears
