92 PA Lurches on Acceleration
Our 92 PA will lurch to the right more often than not on acceleration from a stop and also while at road speed. As well it will pull noticeably to the left when you back off the gas pedal. Any thoughts? Thank you.
Re: 92 PA Lurches on Acceleration
Welcome to AF, tough to diagnose from here, look for loose or rotted out ft subframe mounts or bolts, also frozen inner cv joints, you really should get this to a pro, it sounds dangerous.
any notceable noise coming from that side to indicate bearing or cv . look at all motor mounts if it pull on braking then it a caliper .look at stut mounts and pivots ,sway bar links is some thing to look for keep us informed
