Old 01-18-2010, 08:53 PM
JStin JStin is offline
Evaporator diagnoses.
The wife has had dye put into her 2000 Dodge Grand Caravan A/C twice at 2 different shops but neither one can find the leak.
I have the time to pull the dash but how can I know for sure that the evap. is the problem?
Thanks for any help.
Old 01-19-2010, 12:37 AM
RahX RahX is offline
Re: Evaporator diagnoses.
Most of the time, if you can't find anything else leaking, the evaporator is probably leaking. Have them check for dye at the a/c drain.
Old 01-22-2010, 08:42 PM
hundahunta hundahunta is offline
that year has an evap probe if I not mistaken...you can inspect it from there
Old 01-31-2010, 04:59 PM
oops, double post, disregard
Old 01-31-2010, 05:00 PM
Thanks for your replies.
hundahunta, can you elaborate on the evap probe method? I have the factory service manual for the vehicle. I see I'll need to remove the glove box, disconnect the probe & remove the evap probe grommet. This looks like it will expose a portion of the evap. Am I just looking for any signs of moisture on the exposed evap?
Thanks again.
Old 02-01-2010, 09:53 PM
you usually look for oil on the coil..and dust and debris stuck in that area...if they installed dye usually a uv or black light will expose the leak..
