Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-18-2010, 04:35 PM
fej68 fej68 is offline
4runner axle seals
85 4runner rear axle seals inside and out replacement anybody like to help me locate those seals. Found the inside,no biggy, outside not sure. I think it's where the bearing is in the backing plate. Am I right?
Old 01-19-2010, 07:53 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 4runner axle seals
There's an oil seal and bearing on the backing plate. The oil seal in the axle housing is usually the one that starts leaking. When you slide the axle shaft back in, do not let the weight of the shaft sit on the new seal, or you can damage it.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
