Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-18-2010, 02:29 PM
killermrob83 killermrob83 is offline
passenger side front door panel
The bolt for the power lock actuator worked its way loose and now the actuator is laying in the bottom of the door rattling around. How do I remove the door panel for this 1999 Crown Victoria S model? Thanks for your help.
Old 01-18-2010, 06:02 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: passenger side front door panel
Here is the printed version. There are soms screws hidden behind small trim covers. There should be 6 screws. The panel will pick straight up when all the screws are removed. The panel has plastic hooks that fit into the door frame to hang it in place.
Position the window regulator switch plate aside.
Remove the window regulator switch plate.
Remove the screws.
Disconnect the electrical connectors.
Remove the screw covers.
NOTE: Use care not to damage the trim panel when removing the screws.
Remove the screws.
Remove the interior door handle cup.
Remove the screws.
Remove the front door trim panel (23942).
Disconnect the electrical connector.
To install, reverse the removal procedure.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-20-2010, 05:48 PM
Thanks again way2old, the door trim panel came off like a breeze. Upon closer inspection I discovered that the power lock actuator is riveted to the door and that somehow it broke off. Instead of paying $5 for the rivet, I used a M8X1.25X16 buttonhead bolt and a whiz nut to lock it in place. All is working wonderfully again.
Couple of months ago I believe that you told me that I can replace the door ajar switch that is mounted to the door latch mechanism without replacing the entire latch. Would you be able to get me a part number for that switch? Thanks again.........Rob
Old 01-20-2010, 06:11 PM
way2old's Avatar
TOKEN HILLBILLY
Try this SW 1966A That is the Motorcraft part number. click here.
Old 01-24-2010, 02:19 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Yep you got it. I have used a 1/4 inch bolt, it works great. Button head would be even better.
Mike aka JYD
