Old 01-18-2010, 02:10 PM
niko001 niko001 is offline
Banned
misfuel
Hey guys!
I have a serious situation here. I accidentally mis-fueled my dads diesel Audio A6 with gasoline. Just a few liters, but now I don't know what to do! Help please!
Old 01-18-2010, 05:08 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: misfuel
Originally Posted by niko001 View Post
Hey guys!
Have the fuel tank drained just to be safe and refill with correct fuel.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 01-18-2010, 05:13 PM
danielsatur danielsatur is offline
Re: misfuel
Check your receipt for $/gal !
If it's just a little, I wouldn't have a problem putting alot more diesel in it.
3-liters is nothing, we had a dozer, that took 6-gallons of gas to start it's diesel engine.
Diesels, were design to run on all kinds of blended bio fuels.
Usually it's people putting diesel fuel into there petro cars.
Old 01-18-2010, 05:29 PM
RahX RahX is offline
Re: misfuel
I wouldn't mess with it, drain the tank. I imagine the A6 doesn't have that big of a tank and any percentage of gas that is over a few percent will damage a diesel I'd rather dump a 100$ worth of fuel than pay 4-5 figures for a new engine.
Old 01-18-2010, 06:07 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: misfuel
It's not the engine itself that is damaged by gasoline contamination, its the high pressure diesel injector pump and injectors.
Older, primitive diesels, like that dozer are relatively difficult to harm. But the newer auto diesel engines are VERY sensitive to a misfuel.
As noted above, have the tank drained and the fuel system flushed. Injector pumps and injectors are very expensive to fix.
Old 01-19-2010, 09:49 AM
jani_O jani_O is offline
Banned
Re: misfuel
The same thing happened to my girlfriend a few months ago... you should really drain the tank. That's what I did and I had no problems. And I also put a special misfuelling protection on so she won't make the same mistake again )
good luck
Old 01-19-2010, 12:25 PM
Re: misfuel
Isn't the diesel fuel nozzle bigger, and really don't fit into the unleaded spout on a petro car?
Old 01-19-2010, 01:14 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: misfuel
Diesel nozzle is bigger. The car is diesel and they put the smaller gasoline nozzle in by mistake.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-20-2010, 11:32 AM
Banned
Re: misfuel
ok, thanks guys! I drained the tank and it looks like I won't have any problems. What kind of misfuelling protection are you talking about? I guess I should really get one, although I'm pretty sure I won't make the same mistake again
Old 01-20-2010, 12:13 PM
jdmccright's Avatar
The RustBuster
Re: misfuel
BWM has just come out with a new fuel filler mechanism to prevent the smaller gasoline nozzle from opening the flap door in the filler neck opening, appearing on their X5 diesel model. As far as I know there is no retrofit product.
From what I've read, a few liters of gasoline shouldn't be much of a problem if you can dilute it with diesel as much as possible. You don't mention a model year, but tank capacities are between 70-80 L. So 3-5 L of gas in an 80-L tank may not even be noticeable. But it may run rough or give lower fuel economy until you can dilute it with more.
To prevent it from happening again, you'd be best to resort to visual cues such as a DIESEL FUEL ONLY label or paint the gas cap green...Audis have a little door to hide the filler cap. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 01-20-2010, 12:15 PM
Banned
Re: misfuel
glad to hear that the car's ok
well, there are several protections I found on the web which are perfect for people who don't think while tanking Try not spamming this forum by having 2 accounts to promote your interests.
