Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-18-2010, 12:56 PM
adalechevyboy adalechevyboy is offline
2004 cvpi problem
crown vic squeek in engine compartment where belt is for bout 15 mins when cranked in the morning
Old 01-18-2010, 02:02 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2004 cypi problem
Possibly bad belt or bad idler or tensioner pulley bearings.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-18-2010, 09:18 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Remove the belt. This can be done with a 3/8" socket wrench or breaker bar on the tensioner. Spin each pulley by hand until you find which one is squeaking. Like way2old said, it's likely the idler or tensioner pulley but the alternator or water pump bearings can go bad, too.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
