Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 01-18-2010, 12:30 PM
Oldsmobile Doctor Oldsmobile Doctor is offline
3.4 Over Heating
I had someone last night asking me over the phone about there Oldsmobile overheating. It is mid 90's with a 4.3 Quad-4 in it. When they drive it with the heater on it over heats. When they drive it with the heater off it is ok. I haven't looked at the car personally and can't see how it could be doing that. Maybe the other way around.
Thanks....
Old 01-20-2010, 05:56 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 3.4 Over Heating
The heater core is part of the cooling system so if the cores clogged could be why its over heating when off.
Has anyone checkked the heater lines while the engines warmed up to see if they are hot or cold ?
Or if you can tell whether warm/hotcoolant is moving thru the lines when the engines running?
1999 Grand Am SS 3.4 OHV
Old 01-20-2010, 08:46 PM
They say that the heater is working and it over heats when they use the heater
Old 09-23-2010, 11:37 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
i would say then that radiator is partially plugged so that when the heater is turned on most of the water gets routed through the heater core, bypassing the radiator and causing overheating. If the car has worked well in the past with the heater turned on, then I would suspect a partially plugged radiator. take xeroinfinity's advice and feel for hoses that are hotter/colder than they should be
Old 09-24-2010, 06:14 AM
Thanks, they never got past the asking about stage..
