Old 01-17-2010, 07:09 PM
sprocket401 sprocket401 is offline
Question 97 2.2 head gasket leaking
head gasket leaking antifreeze on block not in oil. this is the second one. about 140,000 miles on this one. i heard if you take the outer head bolts out an put a good coat of pipe sealant on them and reinstall them this might take care of the problem. has anyone heard of this? also its been awhile since i did one if you remove the head to put a new gasket on can you leave the fuel rail on it? this is just a old work car i drive 100 miles a day hate to send it to the grave yard.so far i got240,000 miles on it.it has the small 4cyl in it
Old 01-17-2010, 07:38 PM
danielsatur danielsatur is offline
Re: 97 2.2 head gasket leaking
I never used this protect, it might be worth a try, see
www.youtube.com/watch?v=3suQy44G_B0
Here's the Red neck method, see
www.youtube.com/watch?v=7BjuAHBxnEw
Old 01-17-2010, 08:35 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I would never use any liquid that is intended to seal a leak. Most don't work. If you find one that does work, then logically it should plug the radiator, heater core, and passages in the block and head. They're designed to harden when exposed to air, but if the coolant gets low or there's an air pocket, guess what happens?
I like the redneck way!
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-18-2010, 08:09 AM
Do auto shops charge $800 for this repair?
The Steel Seal Ad was tagged by Google @ the top of Post! It's a LIFETIME GUARANTEE, use PayPal for extra insurance.
Old 01-18-2010, 03:09 PM
Is this stuff like crack to a car?
Old 01-18-2010, 04:52 PM
J-Ri's Avatar
Not sure what shops charge, I do nothing with the billing, I won't dispute that number. Sounds close.
Ads by Google are still ads... Steel Seal pays for the ad, Google just recognizes key words eg. "head gasket leak", and then inserts the ad for this product. It's a wonderful method for advertising, have ads related to the topic, makes perfect sense. I have never seen a stop-leak product that actually worked for more than a few weeks. Because of how it works, I'd be very hesitant to put it in a car that I was going to repair if the stop-leak didn't work. I put some in my truck years back... I still have some hardened inside the radiator because it didn't work fast enough. The coolant got low, and the part exposed to air hardened. I assume it's hardened inside the block as well. I have never used this product, so for all I know it works, I just wouldn't go experimenting on anything I own. The only time I would use a stop-leak product (again) for any system was if I was going to junk the vehicle if the $10 fix didn't work.
N20 is like crack, I'd say stop-leak is more like huffing expanda-foam
Old 01-18-2010, 05:19 PM
How about Dope!
I'am looking for a cheap car, that needs a fix, $800 for 1/2hr work isn't bad.
The stuff they put in the Cash for Clunkers cars works good!
Old 01-18-2010, 05:42 PM
J-Ri's Avatar
I thought you meant $800 to replace the head gasket.
I won't say that nobody has ever charged for a repair and only added a chemical, but I think it's very rare.
